Routing saddle slots http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=3922 |
Author: | Andy Zimmerman [ Mon Nov 28, 2005 4:09 pm ] |
Post subject: | |
Up until now, I have used pre-routed bridges. What type of jig set up do most of you use to route your saddle slots? Also, do you do this before shaping the bridge or after Andy |
Author: | RussellR [ Mon Nov 28, 2005 7:51 pm ] |
Post subject: | |
Hi Andy I could have sworn Don W had one in the jigs section but I can't see it now. At the moment I am just using a simple one I got from the Campiano book, just two pieces of plywood, and you run the laminate trimmer with a side fence on down the edge. I have been working on one which slides on draw runners, but I haven't quite got the kinks worked out, and after visiting Dave White, he gave me some new ideas on bridge angle, so I may be changing. What I would say is don't try to use a dremmel, I just found it unsuitable as it wasn't stable enough, I use a laminate trimmer with a 1/4" shank bit. In a discussion recently Mario showed his method, he use a bridge that is slotted through and cuts the slot on a table saw. Simple but very effective. |
Author: | Colin S [ Mon Nov 28, 2005 8:44 pm ] |
Post subject: | |
There is the complete bridge making jig by John How in the Jigs tools and techniques section. This include the saddle routing set up. Colin |
Author: | Andy Zimmerman [ Tue Nov 29, 2005 7:02 am ] |
Post subject: | |
Merci Beaucoup!! Andy |
Author: | John How [ Tue Nov 29, 2005 1:03 pm ] |
Post subject: | |
Good point Terence, my router has a square bottom and I have marked my jig so I know which side of the router goes where although I discovered the need before I marked it if you know what I mean. |
